Суббота, 28.12.2024, 14:04
КРОТ "СМАРТ" - Страница 31 - Форум
КРОТ "СМАРТ"
AndrewДата: Воскресенье, 04.02.2018, 12:52 | Сообщение # 451
http://www.radiodom.org/test-3-.apk
nonametdyДата: Воскресенье, 04.02.2018, 13:15 | Сообщение # 452
Andrew, "nonametdy, Hi , Who wrote the BLE Conector application? It's about twice as big as my whole application.Can I make one "Conect" button and simplify as much as possible? "
"Hi , Who wrote the BLE Conector application? "  - No offence, but you must be seriously stupid!
Off course it is big.. There is included all possible think of elements, for helping you port or implement your
code with it... No need for searching for missing functions.. They are all included..
And if you even once, could read descriptions,, but no... There I wrote it to be, a bear bone application, not a final product..
Just for testing purposes...
I was tempted to send you only absolutely needed, stripped down, code.. But no, I was kind, and taught of helping you out
as much as possible...
I seriously regret participating in first place. Please kindly  delete all of the material I sent you...
It has shoved to be, as throwing pearls to pigs !!
If I only had knew, how egocentric, narrow minded and equipped with tunnel sight you have showed to be.. If I only had knew.
This is not meant to be offending, apologize for that.. But seriously, grow up, and behave as an mature man..
After all, you are born 1959, and should have developed common sense, and some maner  by now..
With Best regards.
No Name Today
Добавлено (04.02.2018, 14:09)
Andrew, http://www.radiodom.org/test-3-.apk , nope,,,, Error 507, Unable to connect...
Nothing reaches to bt module.......
Добавлено (04.02.2018, 14:15)
Andrew,  You know.. I could write complete frontend Smart->KPOT. One button as requested..
With AutoConnect, no need to fiddle every time with searching and connecting.. Just power on, and off you go to the KOP
But, NO !!  I don't do it. I seriously have no desire to do it. Neither participate ever more..
Сообщение отредактировал nonametdy - Воскресенье, 04.02.2018, 13:17
AndrewДата: Воскресенье, 04.02.2018, 13:58 | Сообщение # 453
eek No comments!
de-si-gnДата: Воскресенье, 04.02.2018, 14:47 | Сообщение # 454
ошибка 507, не удалось подключиться
В тесте nonametdy блютуз НЕ ДОЛЖЕН быть сопряжен с Андроидом.
Andrew, если у вас нет рабочего модуля Блютуз 4, то работу приложения можно проверить на эмуляторе https://www.youtube.com/watch?v=LU-Iq_G5iEk
Под видео ссылка на скачивание.
Добавлено (04.02.2018, 15:47)
Цитата nonametdy ()
You know.. I could write complete frontend Smart->KPOT. One button as requested..With AutoConnect, no need to fiddle every time with searching and connecting.. Just power on, and off you go to the KOP
 nonametdy, So make such application for BLE! We will be happy, and Andrey including  smile
For Bluetooth 2 already got the app from Andrew.
AndrewДата: Воскресенье, 04.02.2018, 19:12 | Сообщение # 455
Каким образом эмулятор мне "сэмулирует" сам модуль и Крота? Эмуляторы не для таких приложений...
Похоже осталось нас двое..(    Господин фин как то очень болезненно отреагировал на мой вопрос "Кто писал приложение?". Я  Хотел понять сможет ли он совместить мои приложения со своими, а он начал про животных рассказывать.. (
А теперь главное,  Что я хотел проверить - проверено!  Есть реально работающая программа с удовлетворительной   задержкой на НС-08 модеме. Еще сделаю некоторые доработки самого приложения и адаптирую "8" и "9" версии "Рейтинга" под "Смарт". Кто захочет попробовать - попробует...
Как я уже неоднократно писал, у меня нет не 10 модема и не 4 блютуза... И изучать подробно блютуз модемы и Андроиды тоже не вижу огромного смысла для себя,  тем более у меня тоже есть работа , которая не для души а для "тела" и не только моего..)
Хотите подключить 10 модем - пишите приложения соединения с ним , с одной-двумя кнопками.  А я подключу его к своему проекту. Это не лично вам, а всем кто нас читает и особенно сильно занятому  Поташову, думаю  для него это дело 20 минут...)
Всегда на связи!  beer
vasmaДата: Понедельник, 05.02.2018, 07:39 | Сообщение # 456
Возможно будет полезно знать, что приложение созданное в app inventor2, с поддержкой BT4.0 , будет работать на минимум ANDROID 5, а не 4.4, как у меня(
http://www.martyncurrey.com/arduino-hm-10-and-app-inventor-2/
Владею BT4.0 модулем JDY-08, перешитым в HM10 v6.04, но пока нигде не примененным (хоть и есть ВЕЛИКИЕ задумки)) Готов передать Автору Крота для... пользы дела. Было-бы неплохо отказаться полностью от дисплея
nonametdyДата: Понедельник, 05.02.2018, 09:15 | Сообщение # 457
Andrew,
In Test-3_(apk)
1. Download,  edu.mit.appinventor.ble.aix
2.  MIT App Inventor->EXTENSION->"Import Extension" / From My Computer
3. From Extension, Drag BluetoothLE in to Screen1
4. Build app -> Connect BLE
Сообщение отредактировал nonametdy - Понедельник, 05.02.2018, 09:22
nonametdyДата: Понедельник, 05.02.2018, 09:43 | Сообщение # 458
Diagram
Прикрепления: 6600889.png (181.5 Kb)
AndrewДата: Понедельник, 05.02.2018, 10:54 | Сообщение # 459
Спасибо не знал. А если  подумать.. у многих ли жителей Украины есть такие гаджеты...)
de-si-gnДата: Понедельник, 05.02.2018, 11:17 | Сообщение # 460
Спасибо не знал. А если  подумать у многих ли жителей Украины есть такой гаджет...)
В 2013 год Smart или Bluetooth 4.0 Low Energy включен в новую прошивку Android 4.3...
Android 5.0 появился в 2014 году
vasmaДата: Понедельник, 05.02.2018, 19:04 | Сообщение # 461
Ээх, жаль.. Но, думаю Автор, в любом случае придет к мысли, что идеальный Крот - это минимальный набор железа, встроенного в катушку, с автономным питанием и безпроводной связью (BTилиВLE) плюс базовый блок (смартфон) на андроиде, который будет выполнять функцию мозга по обработке информации, управлению и индикации. Плюсы здесь очевидны, устраняются паразитные наводки и помехи, связанные с качеством кабеля и разъема, гигагерцовые процы в телефонах против Xмеги.. но.. электромагнитная совместиность блютуза внутри катушки .. эксперименты покажут, да и софт для андроида требует незаурядных мозгов.. уверен, Автор ими обладает) впринципе, тот-же деус, но гораздо лучше и в сто раз дешевле. Такие мои думки.
AndrewДата: Понедельник, 05.02.2018, 19:14 | Сообщение # 462
Цитата vasma ()
Такие мои думки.
В Деусе не так.., там просто прибор разделен на 2 части, измерительную часть и "все прочее". Сделать как в Деусе для меня гораздо проще, чем написать хорошее приложение для  Андроид, это  отдельная наука на освоение которой нужно много  время..
TCBДата: Понедельник, 05.02.2018, 20:07 | Сообщение # 463
Встроенная в катушку начальная обработка это, на первый
взгляд, очень хорошо, а если еще избавиться от проводов так вообще прекрасно…
Но если подумать, то по большей части такое решение может
оказаться простым маркетинговым ходом, чтобы отсечь всех изготовителей «левых» катушек.
А ведь многие хотят иметь под разные задачи разные катушки.
И чем больше электроники напихано в катушку, тем проблематичней это становится.
У «фирмы» и у «копателя» интересы не всегда совпадают.
nonametdyДата: Понедельник, 05.02.2018, 20:46 | Сообщение # 464
de-si-gn, Make a test,, Start Smart-Kpot. How fast does Android get updates from Kpot ?? Think of walking speed vs. updating speed..
Test why it is slow. Look at Android screen, for example S5F1 , now manually change F1 to F3 by pressing button switch Manually on Kpot..
Look how long it takes, before change will be updated... Or S5 to S6 ......
Also, cannot use in real life... Ground Balance is missing from android, as is PinPointer...
But Heyyy! There is step counter and Map......
Still long way to go, before ready for "KOP"
Also it seems like it would occasionally hang, stop responding, without any warning.. That's bad on KOP.. Reaching end of field, before notice.
All gold treasures left behind..
I just Jumpstarted Mole3 with BLE at baud rate 38400 , and such findings. Perhaps therefore stops responding.
So please test, if confirmed..
AndrewДата: Вторник, 06.02.2018, 11:09 | Сообщение # 465
Согласен..Кабель от катушки до блока меня лично не чем не напрягает.. Другое дело кабель от блока до ушей...
Вот от него желательно избавляться.. Может доработаем плату?  ФМ трансивир +БЛЕ+ прочее .
