КРОТ "СМАРТ"
Andrew | Дата: Воскресенье, 28.01.2018, 22:15 | Сообщение # 331 |
| Folny, I am intressed the bit depth and speed ADC!
Folny | Дата: Понедельник, 29.01.2018, 08:34 | Сообщение # 332 |
| Hello Andrew
You have to study it on the web there is everything written about ESP32 I think it would not be a problem to write the code that would work. If you decide to implement a new project with this module, I would like to share the development of the new version, this development board is really cheap and has a great use. For examples of a video with a simple DAC setting, find more information on the web.
https://www.aliexpress.com/item....ifyAB=5
https://www.youtube.com/watch?v=RlKMJknsNpo
nonametdy | Дата: Понедельник, 29.01.2018, 11:14 | Сообщение # 333 |
| Folny, Very interesting and nice board, great catch !
Добавлено (29.01.2018, 12:14) --------------------------------------------- de-si-gn, Andrew,
"Для тех кто хочет сам написать приложение. На запрос символ "9" , "Крот" ответит 5-ю байтами - символ 'A' , числа - VDI, Ampl , X , Y." Getting bad translation, so don't fully understand above sentence.
Contacting HM-10 module with "Serial Bluetooth Terminal apk" , and sending character " 9 " the Mole responds !! "A" (without coil connected)
- Looks like connection works ??
Сообщение отредактировал nonametdy - Понедельник, 29.01.2018, 11:29 |
Andrew | Дата: Понедельник, 29.01.2018, 11:46 | Сообщение # 334 |
| nonametdy, Download the "terminal" application and send "9".
nonametdy | Дата: Понедельник, 29.01.2018, 12:39 | Сообщение # 335 |
| Andrew, ""Download the "terminal" application and send "9".""
You don't understand ?
I just did .. And Mole respond A..
Perhaps wait for de_si_gn , coming online. Maybe he can explain it in Russia to You.
KPOT-Android gives still Error 507. Unable to connect bla bla bla.
Perhaps we should sponsor You an new BLe Phone..... How much for such phone in Ukraine, (or Your beloved aliexpress) ?
Андрей, "" Скачать "терминал" приложение и отправить "9". "" Вы не понимаете? Я только сделал.. И моль ответить A.. Может быть, ждать де_си_гн, придя в Интернете. Может быть, он может объяснить это вам в России. Кпот-андроид дает еще ошибка 507. Не удается подключить бла-бла-бла. Может быть, мы спонсировать вас новый BLE 4 телефон.... Сколько за такой телефон в Украине, (или ваш любимый aliexpress?)
!!!!! Completely bad translation !!!! !!!!!! Полностью неправильный перевод !!!!!!!!!!!!!!!!!!!
Добавлено (29.01.2018, 13:39) --------------------------------------------- de-si-gn, Hi. please try. ***************************************************************************************** 1. download https://play.google.com/store/apps/details?id=de.kai_morich.serial_bluetooth_terminal&hl=en
2. Connect HM10+KPOT
3. Open Serial Bluetooth Terminal -> check Settings -> Devices -> Bluetooth LE -> Scan + select HM10, Settings-Settings -> Show Timestamps (off), Send -newline None.
4. Upper bar click icon Connect.
5.in terminal, Send " 9 "
6. Kpot+Hm10 respond " A "
Tell Andrew the results !
Сообщение отредактировал nonametdy - Понедельник, 29.01.2018, 13:17 |
Andrew | Дата: Понедельник, 29.01.2018, 15:55 | Сообщение # 336 |
| Цитата nonametdy ( ) .in terminal, Send " 9 "6. Kpot+Hm10 respond " A " and 4 bute!
Andrew | Дата: Понедельник, 29.01.2018, 15:56 | Сообщение # 337 |
| Здесь новая прошивка и приложение с обратной связью, для скорости 38400 http://www.radiodom.org/KPOT.rar С ней уже можно идти на коп даже с 06 модулем.. Взамен Жду видео! )
Угадайте цели..)
de-si-gn | Дата: Понедельник, 29.01.2018, 17:21 | Сообщение # 338 |
| Andrew, HM10+KPOT (9600) Serial Bluetooth Terminal:
nonametdy | Дата: Понедельник, 29.01.2018, 17:44 | Сообщение # 339 |
| de-si-gn, send in terminal 2002 , lcd backlight off.. Send 1001 Backlight on
Добавлено (29.01.2018, 18:25) --------------------------------------------- HM10 module and connection works.
So, MoleAndroid apk.................
Добавлено (29.01.2018, 18:44) --------------------------------------------- Andrew, Sorry, no joy.. Phone hang, black screen! (38400 http://www.radiodom.org/KPOT.rar )
Terminal connection works......
Сообщение отредактировал nonametdy - Понедельник, 29.01.2018, 18:24 |
de-si-gn | Дата: Понедельник, 29.01.2018, 18:06 | Сообщение # 340 |
| Цитата nonametdy ( ) send in terminal 2002 , lcd backlight off.. Send 1001 Backlight on Это работает!
nonametdy | Дата: Понедельник, 29.01.2018, 18:20 | Сообщение # 341 |
| de-si-gn, Great. Connection and module is OK.
Kpot.apk not so good.
We need to sponsor / collect some money, and buy Andrew a new Bluetooth 4.0 phone.
de-si-gn | Дата: Понедельник, 29.01.2018, 18:48 | Сообщение # 342 |
| Цитата Andrew ( ) Здесь новая прошивка и приложение с обратной связью, для скорости 38400 Приложение при подключении блютуз (HC -06 скорость 38400) виснет (черный экран)
Добавлено (29.01.2018, 19:48) --------------------------------------------- Вот так приложение сделано у Minelab: https://youtu.be/DcXSGIeK4jE https://youtu.be/foFKTw-JqcE
Сообщение отредактировал de-si-gn - Понедельник, 29.01.2018, 18:54 |
Andrew | Дата: Понедельник, 29.01.2018, 19:04 | Сообщение # 343 |
| Цитата de-si-gn ( ) Andrew, HM10+KPOT (9600) Serial Bluetooth Terminal: 41 = 'A'
nonametdy | Дата: Понедельник, 29.01.2018, 19:25 | Сообщение # 344 |
| Andrew, we get Character "A" Not Hex 41... How come ?
Andrew | Дата: Понедельник, 29.01.2018, 19:26 | Сообщение # 345 |
| Цитата nonametdy ( ) Phone hang, black screen Цитата de-si-gn ( ) виснет (черный экран) А вы прошивку на Кроте поменяли?
